patssle
May 25 2014, 08:05 PM
Anybody know if the input/output of the Vellios oil tank NPT fittings are 3/4" or 1"?
Thanks.
Steve
May 26 2014, 07:20 PM
I'm looking at his old catalog and it says 914/6 Oil Tank with -12 AN Oil Line Connections.
Made from Vinyl Ester (will not rust) Part number OT02
It listed for $450.00 back in January 1991
Justinp71
May 27 2014, 05:43 PM
not sure of the NPT thread size, but I know mine has AN-12 in and AN-16 out (with its adapters to the tank)... I know the outlet was very large.
sixnotfour
May 29 2014, 09:04 PM
3/4 pipe threads, same size as -12, you can get a -16 an to 3/4 pipe if so inclined..
patssle
May 30 2014, 08:42 AM
The tank is indeed 3/4 NPT. However that does not equal its size - measuring the ID it comes out to .89" which is why I was so confused. Also while -12 AN is supposedly the same size - the ID of the NPT to AN fitting is actually a tad smaller on the AN side. Whereas the -16 AN is slightly bigger.
It was very frustrating to find out the size of the NPT - measuring does not give an accurate account because the actual size is bigger than it says!
