DNHunt
Jan 16 2005, 02:07 PM
I know, new motor, the rings aren't seated. So I had it apart to fix an oil leak and I started looking around. Oill in the intake behind the valve. Ah sh*t!
DNHunt
Jan 16 2005, 02:09 PM
But, wait there's more. Oil in the intake runner.
DNHunt
Jan 16 2005, 02:10 PM
There's still more. Oil in the plenum.
DNHunt
Jan 16 2005, 02:17 PM
THere's still More! Oil in the vacuum line to the PCV valve.
So, could it be that the rings aren't seated so there oil remaining in the cylinders. Because of high crankcase pressure and higher vacuum, oil from the crankcase is being carried to the intake at a higher than stock rate.
Maybe I'll need a breater system or a different PCV valve
Dave
machina
Jan 16 2005, 03:07 PM
are you sure you didn't overfill?
if not it could be your case/head venting.
is that a 2270?
J P Stein
Jan 16 2005, 03:22 PM
Probably the rings.
Are you using non-detergent oil?
Mark Henry
Jan 16 2005, 06:32 PM
Are you blowing a lot of smoke?
If it was the rings or guides the thing would be like a mosquito fogger with that much oil!
Looks more like your pumping oil up the breather tube to me...how's it plumbed? Better pic please....
Mark Henry
Jan 16 2005, 07:12 PM
Hmmmm....I wonder....with your 2270 and stock plenum are you creating so much vacuum that your are actually sucking oil right out of the engine?
Maybe you will need an external breather that sits high in the bay. Say a 4" piece of 1 1/2 tube, on end with a return on the bottom, the inlet just over half way up and outlet to the TB at the top. Put a couple of SS scrub pads or some kind of baffle in the tube.
Just an idea....
Gint
Jan 16 2005, 07:41 PM
Was Andy over there taking pics?
Wish I could help Dave. I'm sure the eggssperts will have some insight.
rhodyguy
Jan 16 2005, 07:54 PM
stupid guess time. if the rings weren't seated, could the the compression be blowing back into the case? call 1-800- georgia. dave's car doesn't blow much out the ex pipe.
kevin
DNHunt
Jan 16 2005, 08:24 PM
Smoking on decel. I had one of the heads off today to get to an oil leak. The cylinders still look brand new. I do believe its sucking oil into the plenum though.
Dave
redshift
Jan 16 2005, 08:27 PM
Ok, so far I am with Mark, especially on the smoking decel.. it just sounds... 'sucky'.
M
Bleyseng
Jan 16 2005, 09:24 PM
How much vacuum are you pulling at idle?
Hmm, how much air you blowing out of the hose from the PCV valve??
Geoff
Porsche Rescue
Jan 16 2005, 09:56 PM
I have always believed that smoke on decel is from oil leaking by the exhaust valve guides under compression. If it was passing intake guide (s) as well that would get it to the intake side.
Mark Henry
Jan 16 2005, 10:05 PM
Nah....fresh heads new guides and Len (Jake) built them...I've seen T1's do this, you'll need some kind of breather box.
Don't think Jake will be around till Tuesday, if your trying to get him on the phone.
scotty914
Jan 16 2005, 11:23 PM
smoking on decel is sucking oil throught the intake valve guides or from case due to high vacumn
do you have a decel valve on it
machina
Jan 17 2005, 06:47 AM
My 2270 was puking lots of oil last race but I had overfilled it. I have the heads and breather vented to a 1 qt tank. Next race I'll be more careful with the oil level. With the accusump, oil coolers and lines, its hard to tell when the level is right sometimes.
Joe Ricard
Jan 17 2005, 07:19 AM
It's probably just me but, I don't vent my crankcase or heads to the intake.
cnavarro
Jan 17 2005, 07:58 AM
I had the same problem with my engine. It got so bad the puke box would overflow. There were two issues- the puke box was too small and secondly, I mounted it way too low. That's what it sounds to me. The stock pcv system couldn't hold up to the larger displacement.
Charles Navarro
LN Engineering
http://www.LNengineering.comAircooled Precision Performance
Walter
Jan 17 2005, 09:23 AM
QUOTE (cnavarro @ Jan 17 2005, 05:58 AM) |
... I mounted it way too low.
Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
Charles,
Was that in your type 3? If so, I can relate: mounting a case vent box in a type 3 is a nightmare since total height is so little...
Where did you eventually mount it?
I had heard earlier of vent boxes that are too smal for a large type 4. The small bugpack ones have been replaced quite a few times for larger ones IIRC.
Walter
Jake Raby
Jan 17 2005, 10:33 AM
The rings definately have not seated yet. It needs to be driven harder!
Get the car into second gear and take it to 6,000 RPM 5-6 times each time accelerating briskly and then backing totally out of the throttle while leaving the clutch engaged. This will bring the vacuum up very high and will force feed the rings to seal....
The other thing that will cause this is lack of crankcase ventilation, more vent is needed when the rings are not seated as well.
These same pistons and rings have been used dozens of times with Nickies and I get them to seat on the dyno in less than 30 minutes...
DNHunt
Jan 17 2005, 11:01 AM
Thanks Jake
Ok will do. But, probably not in my neighborhood. That gonna get someone pissed. Gotta avoid the noise cops.
That may not happen for a while. Engine and tranny are out of the car. I'm changing tranny's and replacing 1'st syncho. Also, it supposed to rain buckets for about 40 days.
Cali guys sent their rain up to us.
Dave
Dave
914werke
Jan 17 2005, 11:27 AM
QUOTE |
It needs to be driven harder! |
You heard the man!
Drive it like ya stole it Dave
rhodyguy
Jan 17 2005, 01:52 PM
we should start a ticket pool. "what day will dave get his first ticket". i volunteer for to be the driver for the break in cycle. better hook up your tach dave. so, was my guess right regarding the compression leaking into the case?
k
