Early production 1970 914/6.
1970 914/6. Original color Ivory over black. Missing original engine which was replaced with a 2.4 911-T #6130202. Side shift transmission. Original transmission comes with the car. If you get lucky you might find the original engine as the previous owner sold it to install a hot rod motor.
Car was hit in the right rear at some point and that fender/bulkhead was replaced.
Correct 914/6 Fuchs 5.5 x 14. New PMB brake calipers all around. Carbs rebuilt. Runs well. Has one correct outer rocker and one replacement “glass” piece. Restoration Design making these again. Original glass including windshield. Door jamb decal still intact. Car was painted years ago but not “jammed”.
Original heat exchangers in good condition. According to seller he has “lots of spares” that may be negotiated into the purchase.
All in all pretty rust free save for any area under the hell hole. Inner rockers appear solid and areas around the gas tank are good as well. Front pan is clean as is the trunk.
I’ve driven the car and it’s a typical 914 with age which is to say it has creaks and rattles. (Top and back glass). The engine is spunky and with the additional torque is quite fun to drive.
IF I didn’t have a 356 in a million pieces I’d buy it and turn it into a GT faster than you can blink your eyes.
lindseych@msn.com
(804) 405-1727
Asking $28,500
(Additional photos are available)
