r_towle
May 26 2014, 07:36 PM
Has anyone drained a 911 tank to replace the strainer?
How did you drain it?
Rich
May 26 2014, 07:39 PM
Run the fuel pump and pump the gas into a gas can?
r_towle
May 26 2014, 07:41 PM
seems simple enough, but no one explains where to apply the mystery jumper....
I know I could hotwire it, and I may just do that to make life easier....
Rich
messix
May 26 2014, 07:49 PM
jumper fuel pump relay?????
ripper911
May 26 2014, 08:01 PM
Pull it out and turn it over in the yard.
McMark
May 26 2014, 11:16 PM
What year?
Or go get a $25 fuel pump and a length of hose and go down the filler pipe.
r_towle
May 27 2014, 10:56 AM
we have a siphon hose, going to do what we can to get most of it.
The last bit will just be a "man up" exercise with the doors and windows open, some funnels and cans to catch what we can.
Even then, the strainer is at the very bottom of the tank.
No matter what, when I pull that out, there will be more fuel there...
Rich
Kansas 914
May 27 2014, 12:48 PM
QUOTE(r_towle @ May 27 2014, 10:56 AM)
Rich
That is when you light a match to see how much is left. Shortly afterward there will be zero gas left I there.
gms
May 27 2014, 03:33 PM
Rich,
here is a picture, it is on the bottom of the tank, it will be by the crossmember for the front suspension
Click to view attachment Click to view attachment
barefoot
May 27 2014, 05:32 PM
QUOTE(r_towle @ May 26 2014, 09:36 PM)
Rich
Siphon it out.
Don't tell us that you never did that as a kid when you couldn't afford to buy gas for your first car.
rick 918-S
May 27 2014, 05:54 PM
What are you up to now?
Cap'n Krusty
May 27 2014, 05:55 PM
Who needed to siphon? A tank of gas for my first car was under 3 bucks, and I got 25MPG ............................... Sometimes it was under 2 bucks, if there was a gas war going on.
The Cap'n
r_towle
May 27 2014, 06:29 PM
QUOTE(rick 918-S @ May 27 2014, 07:54 PM)
Fuel pump strainer is old, clogged and making the fuel pump hot and f-in loud..
So, replacing the strainer...
It's like the sock in a 914, just costs a lot more.
Elliot Cannon
May 27 2014, 06:54 PM
You can't figure out how to drain a fuel tank and you say Pelican is pitiful?
r_towle
May 27 2014, 07:18 PM
QUOTE(Elliot Cannon @ May 27 2014, 08:54 PM)
Without getting gas all over me....
wndsnd
May 27 2014, 07:41 PM
Hose in hole
Mouth on hose
Suck
Oh, and post a picture.
rick 918-S
May 27 2014, 10:25 PM
QUOTE(r_towle @ May 27 2014, 07:29 PM)
Easy fix, Pull the engine and put it in your 914.
Elliot Cannon
May 28 2014, 01:04 AM
QUOTE(rick 918-S @ May 27 2014, 09:25 PM)
Best advice so far.
rhodyguy
May 28 2014, 09:43 AM
like mark said. dig out an old facet and some fuel line.
r_towle
May 29 2014, 06:59 PM
So, still alive and did not blow up....
Pulled the strainer and while there was nothing obvious, when held up to the light the bottom section was clearly coated with a film....possibly lacquer like stuff....
Gotta love the new fuel we are using....
Seems like this is an annual filter to change every spring now....
