QUOTE(matt5596 @ May 27 2014, 06:44 AM)
Looking for (4) lug bolts like these 14x1.50...
Click to view attachmentWhat kind of wheels are you using?
Stock lug nuts are 25mm and alloy lug bolts are 38mm.
Any wheel thicker than a steel wheel needs the longer bolts.
What you have may not be correct. You typically want at least 14mm of thead engaging the hub or rotor.
