QUOTE(bulitt @ May 27 2014, 05:48 PM)
You can buy this at advance auto. @ 24$ Not cheap, Wmart might have it for less?
Needs to set up for 24 hours. Or swing by an auto glass installer- they may give you a shot for free.
Thanks, I'll give that a try!
QUOTE(Dave_Darling @ May 27 2014, 06:23 PM)
Before you glue anything to anything else, it's best to be very clear what is supposed to be permanently attached to what.
If the other side is working well, take the door cards off both and see what the differences are between the two.
--DD
I've had both door cards off completely already to compare. There's a metal bracket that slides up and down in a channel in the piece the vent glass is attached to. This metal bracket that slides up and down is what the glass on the driver's side became detached from. There's blackish adhesive residue on the window from where it was affixed inside the metal bracket.
