On the engine.. No other oil cooler was installed on stock production 6's
M471
May 28 2014, 12:01 PM
Thanks for the info.
M471
May 28 2014, 12:17 PM
QUOTE(gandalf_025 @ May 28 2014, 10:39 AM)
Where exactly on the engine does it mount?
May 28 2014, 12:30 PM
The console on the oil tank. The 6 is a dry sump engine
gandalf_025
May 28 2014, 12:47 PM
The Factory oil COOLER on a 914-6 is mounted to the engine on the drivers side rear of the engine.Toward the back of the car. Here is a picture of a 914-6 oil cooler on an early 911 engine.. Same mounting spot on both engines.
For a 2.5 Twin-Plug, you may want to run a Front Cooler like a GT. I don't know if Eric (PMB) ever did the Copper Oil Lines that run down the Drivers Side
M471
May 28 2014, 02:41 PM
Thanks for all the advice. I am weighing my options. My engine is in the final stages of installation following a complete rebuild.
May 28 2014, 03:03 PM
Sorry, I read oil filter, not oil cooler. RIF
carr914
May 28 2014, 03:07 PM
QUOTE(M471 @ May 28 2014, 04:41 PM)
Which I'm sure was not cheap, which is even more the Reason for a Front Cooler
