I had my 2.0 heads rebuilt for 12mm spark plugs but don't know where to buy ignition wires. I am using a stock distributer.
Recommendations would be appreciated.
lonewolfe
May 31 2014, 07:31 PM
QUOTE(Highland @ May 31 2014, 06:23 PM)
The spark plug wires should be the same.
VaccaRabite
May 31 2014, 08:01 PM
If using a stock dizzy, use stock wires.
IMO no need to use special wires unless you are using some sort of optical dizzy that needs the spiral wound wires.
Zach
McMark
May 31 2014, 08:23 PM
Stock wires will work fine. If you want tight fitting boots, you can get wire ends from NGK in various angles. They just screw onto the wires (just like stock ends). You can even move the rubber washer/boots over to those ends, just like stock.
