I'm about half way into the project to add the 911 drum setup to the rear of Ole Yeller.
Axles are removed (need new CVs), TA's are off and modified for the 911 drum set and I've got the nifty cable/tube set from Tangerine (Chris Foley) to link it all up.
Axles are about an inch short and the bearing carrier is as well (for 7" Fuchs) so the setup will need to move inboard and maybe a little back to align properly.
I think I'm going to use the Type 1 CVs and mod them to take the 10mm pins, strip and powdercoat the axles. I'm 200K miles into the original set of CV (flipped once) so I think a new set of Lobros should last my lifetime.
My handbrake is original and in pretty good shape with the exception of the pressure rod.
I'm not sure this is repairable so I'm looking for a replacement or a "parts" handle from an early car.
Anybody out there that can help with a replacement pushrod?
Rich
214-796-2895
a914guy@aol.com
'71 914-6 3.0L Conversion
