While working on an unrelated project, I took the cover off my fuses and discovered that the cover was warped and the fuse for the fog lights is melted.
I'm running Pilot lights from Camp914 in place of the stock fog lights, and I normally have them on whenever the car is running. The fuse has never blown, so it seems that the circuit is not overloading, but it seems strange that there would be so much heat generated if the circuit isn't overloaded.
I'm wondering if a larger fuse would generate less heat (although that seems unlikely), or if this means I have to re-examine the wiring and change the gauge of the wiring.
Any ideas?
