QUOTE(jwc914 @ Jun 5 2014, 07:10 PM)
ok I will try local hardware stores
I found the o rings at a industrial deal supply. Rebuild two pumps and they both leaked out the electrical connector. Test them under pressure after replacing the o rings.
You also need to clean out the passages in the head with the pressure bypass. They get gummed up with old gas.
