57lincolnman
Jun 8 2014, 08:22 AM
After repainting my '75, the turn signals don't work. Must be a wiring problem. Here's what I know. Parking lights come on front and back , Euro park feature works left and right side front and back (so flasher part of bulbs work). Relay has been replaced. Fuses checked. 4-way flasher doesn't work (obviously). Single green turn signal indicator on tach stays on constantly when ignition switched to accessory or car is running. Thoughts? Your suggestions are much appreciated.
McMark
Jun 8 2014, 09:15 AM
I think you said it. The flasher unit is dead. You must get an OE part. The universal four prong flasher from your FLAPS won't work.
