QUOTE(john77 @ Jun 13 2014, 02:16 AM)
QUOTE(Cap'n Krusty @ Jun 11 2014, 10:38 AM)
QUOTE(john77 @ Jun 11 2014, 10:26 AM)
QUOTE(type47 @ Jun 11 2014, 10:22 AM)
workshop manual 6.2-1/1 says there is a bolt to remove. Looks like the bolt is into the metal body behind the lever system. You might need to remove or loosen the cables to allow removal of lever system out the front of the dash. I haven't done this, this is from what I can find in the workshop manual
Thanks Jim. I took the bolt out no problem, but the cables are a different issue. Haynes says to remove them in the trunk and then take out the control panel with them still attached at the back, but then doesn't tell you where they need to be removed from.
Open the front trunk and look. The connections are right there on the blower unit and air guide valves. Bolts and clips, IIRC, or maybe just clips.
The Cap'n
Okay, I took the two driver's side connections out no problem - unbolt, pop clip - but the passenger side???
Popped the clips but the cables aren't bolted in they're just bent through the control arm. I've tried and tried and tried to unhook them but it's not happening. Am I missing something?
It's the worst job in the 914 world. After rust repair, of course .
Each cable has two adjustments. A, the position of the sleeve on the holder. and B , the position of the moving arm on the wire.
The sleeve clips are difficult to engage and remove, ( use a needle nose or a very small channellock plier) and be careful of the fixed brackets, they're old and fragile
The next torture is to get the wire through the tiny hole in the tiny swivel bolt between the two flat washers. And then tighten it in the correct adjusted position for proper throw.
OH, the joy !
Just sayin'
