I have driven about 500mi since installing my SSI HE's. I now have an exhaust leak.
When I installed these I carefully flattened the stub pipes and annealed the copper sealing rings.
I used neverseize on the studs and used shouldered copper coated nuts.
Question, should I just find the leak and tighten the nuts further?
Also the set-up with the shouldered nuts bearing on the mounting ears of the HE's would seem to create a lot of friction and affect torque values. does anyone install a flat washer under the nut?
I installed the sealing rings "dry" what about a light coating of neverseize or of hi-temp. RTV.
Looking for opinions and empirical knowledge, thanks!
