QUOTE(914Sixer @ Jun 12 2014, 08:12 PM)
Yes, it is easy. Pull door panel and loosen 10mm bolt under vent window. Go to the bottom out side of door and loosen 13mm nut. Spray bolt that holds window post with some PB Blaster. You are now ready to move the post in by turning post screw adjuster in or out as needed. When aligned where you want it tighten bolt and nut.
I agree. This is how the book suggest it be done. It may be in the tech 600 book.
