hndyhrr
Jun 15 2014, 12:02 PM
Lately when driving the car seems as if my feet are hitting each other when on the clutch and brake at the same time... funny my feet are not that big lol. I've attached a pic of what i found this morning when i went looking at the pedal assy. so my question is .... if i clip the bailing wire that the po put on there can i just slip the pedal off and clean it up find the right size roll pin and put it all back together or will i need to pull the whole assy? Was planning on re building it this coming winter, just want to drive the pumpkin now that it is nice out side.
thanks
hndyhrr
Jun 15 2014, 12:03 PM
QUOTE(hndyhrr @ Jun 15 2014, 11:02 AM)
thanks
Click to view attachmentoh and i can see that it moves on the rod when i press it down a little
toolguy
Jun 15 2014, 12:40 PM
Can you grab the pedals and move them to the left and right?? If so, pull the whole assembly out and rebuild it. probably needs new bushings as well as the roll pin replaced. .Easy Saturday job. .
hndyhrr
Jun 15 2014, 12:43 PM
QUOTE(toolguy @ Jun 15 2014, 11:40 AM)
yup
guess i will order parts and tackle it
thanks
euro911
Jun 15 2014, 12:47 PM
Looks like the roll-pin is still in there
You'll need to remove the whole pedal assembly, stick it in a vice and punch the roll pin out. Then the hard part - getting the arm off the shaft. They're usually rusted on. You may need to heat the arm up with a torch to expand it enough to pull it off the shaft.
If going that far, you might as well install a new bronze bushing set too
hndyhrr
Jun 15 2014, 12:49 PM
QUOTE(euro911 @ Jun 15 2014, 11:47 AM)
looks that way but when i push on pedal with my hand it travels to and fro a little bit so hopeful not stuck on shaft.
guess i know what i will be doing when parts get here
thanks
Drums66
Jun 15 2014, 12:52 PM
....History is made to be "broken" take it out(assy)& fix it right!
euro911
Jun 15 2014, 12:59 PM
Some if you guys must type faster than me
toolguy
Jun 15 2014, 01:17 PM
The problem for the most part will be the nylon bushing, which may be almost nonexistent. .
get a bronze bushing set. . it's a straightforward project. . If the existing roll pin is in there loose, you may need to get a larger size and redrill the hole accordingly. . It needs to be a very snug fit. .
bdstone914
Jun 15 2014, 01:36 PM
QUOTE(toolguy @ Jun 15 2014, 12:17 PM)
I would not re drill the shaft to a larger hole if the roll pin is loose. It will result in weakening and cracking the shaft. Remove the pedal set and take it apart. If the shaft is worn wear the lower clutch pedal attaches than replace it. As toolguy said it must be a tight fit. I have extra parts if you need them.
Bruce
76-914
Jun 15 2014, 01:55 PM
Don't mistakenly use a nail set instead of a drift. It will flair some and lodge more tightly if you do.
hndyhrr
Jun 26 2014, 05:46 PM
ok so pedal cluster is re-built and back in car (almost ) here is next question, how do i adjust the cable to the clivus thing. i loosed the nut and had to unwind clivus to get it to go onto pedal cluster and now there is too much slop in pedal. or do i put it back the way it was (clivus and nut) and have to eat dirt and as the husband to help me by somehow grabbing onto the clivus and tugging it forward to get the pin in?
been playing with it for a couple of hours and can't get it.
any suggestions are welcome
thanks
toolguy
Jun 26 2014, 06:02 PM
You don't adjust the clutch there. . just be sure and get at least 6-8 threads into the clevis.
Adjust the clutch at the transmission. . sometimes you might want to add a steel tube over the cable threads before the 2 11mm nuts to take up free cable. .
hndyhrr
Jun 26 2014, 06:28 PM
QUOTE(toolguy @ Jun 26 2014, 05:02 PM)
and this will take up the slop in the pedal? travels about 3 inches before i can feel it do anything when i push it with my hand
toolguy
Jun 26 2014, 08:59 PM
Does your pedal have the spring so that the pedal pulls down with no cable attached?? That's the way it is suppose to be. . . . Your picture shows the pedal in the fully upright position but I can't see if the cable is attached. .
Tightening the cable at the trans will pull the pedal up to where you have the top 1/2 inch play.
At rest, the arm should be angled forward towards the engine when the T/O bearing makes first contact with the clutch. . {That's what the ball shim exercise was to adjust}
If the trans end of the cable's 11mm nuts go too far down, add a metal thinwall pipe to extend where they sit on the cable
Properly adjusted, you should feel resistance immediately when depressed. .
If the cable is really too long, and you have excess play when depressing the pedal, this is a sign the bosen tube had broken lose, at the rear body bulkhead or in the body tunnel and is flexing under strain.
hndyhrr
Jun 27 2014, 10:19 AM
QUOTE(toolguy @ Jun 26 2014, 07:59 PM)
no cable attached in pic.
bdstone914
Jun 27 2014, 11:08 AM
QUOTE(hndyhrr @ Jun 27 2014, 09:19 AM)
Was the lower clutch arm tight on the shaft ?
It should be. If loose it puts all the stress on the roll pin which will eventually break.
I can see the spring on the pedal set and the clutch pedal is in the depressed position as it should be. As suggested, adjust the cable at the trans end. Use an extra clutch fork yoke on the cable if you have one. It works better than the 11mm nuts.
Bruce
hndyhrr
Jun 27 2014, 12:10 PM
QUOTE(bdstone914 @ Jun 27 2014, 10:08 AM)
Bruce
lower arm is tight. don't have clutch fork yoke, will get under there this afternoon and tighten it up.
thanks guys
much appreciated
toolguy
Jun 27 2014, 12:12 PM
with no cable attached to the pedal, the spring on the clutch pedal shaft pulls it down, not up. . . . it should not stay in the upright position if the pedal assembly is properly assembled. .
the cable tension from the pressure plate is what pulls the pedal back up..
hndyhrr
Jun 27 2014, 02:01 PM
QUOTE(toolguy @ Jun 27 2014, 11:12 AM)
in my pic the clutch pedal is laying on the back wall not up by brake pedal
toolguy
Jun 27 2014, 02:51 PM
Sorry my error, it looks correct in the picture. . .
With the clevis connected, go back to the trans, connect everything around the roller pulley, and start tightening the 11mm nuts until the pedal is pulled up to within 1/2 inch of it highest possible place. .
That 1/2" clearance allows to throwout bearing to 'gently' ride on the pressure plate. . . add the other 11mm "pal" lock nut. . you should feel an almost immediate resistance of the pressure plate springs when pressing the pedal. . not mussy, it's a solid resistance of the pressure plate fingers being depressed. .
Dave_Darling
Jun 27 2014, 03:13 PM
Grab the solid end of the cable at the transmission end with a pair of vise-grips. That will allow you to pull the cable against the pedal spring so you can get it to where you can get the (crap, the word escapes me!) fulcrum thing up onto the throwout lever.
The vise-grips are also useful to keep the cable from twisting while you're trying to tighten or loosen the adjusting nuts.
The plural there is very deliberate--I always double-nut the cable, because I have had single Nyloc nuts back off and mess up my clutch engagement.
--DD
hndyhrr
Jun 27 2014, 03:37 PM
thanks
will let you know
