Was out for a drive today and went to shift gears and the engine revs shot up
Was able to let the clutch out and the revs went down. Overall not a good situation in traffic. After pulling off I discovered that the clip on the clutch cable had come off and hooked the accelerator cable. So every time the clutch was depressed the engine revved!
Tough fix on the side of the road! But this might ought to be an annual check for everyone. Not sure if there is a problem with the clasp or if it was a freak occurrence.
