Hi folks. I've installed an MSD StreetFire ignition in my 914. To get the tach to work, I had to buy their 8910 tach adapter, which solved the problem. Everything's working great now.
So today I decided to clean up the install by mounting the tach adapter somewhere, and dressing the wiring nicely. I'm sure some of you have done this, so where/how did you install the tach adapter? My first inclination was to bolt it to the firewall, which is where I put the coil and the StreetFire, but the tach adapter gets pretty hot, and the firewall is covered with that heavy vinyl (I think) sound insulation. Is that OK? Or is there a better place to put it?
I think the 8910 dissipates about 30 watts, so it gets pretty hot to the touch, and I wasn't sure how the vinyl would like that.
All suggestions appreciated, especially with pictures!
Thanks,
Jim
