john maples
Jun 21 2014, 02:23 PM
Hi,
I was wondering what the effect would be when running FI on an engine with a carb cam?
Any ideas?
Thanks,
John
colingreene
Jun 21 2014, 03:06 PM
Depends on the type of fuel injection,
If its the stock fuel injection it will not run well if at all.
Aftermarket stuff if programed correctly it will run fine.
jmill
Jun 21 2014, 03:08 PM
I'm far from a FI expert but carb cams usually have significant valve overlap. With stock FI and a carb cam, I would think you would run the risk of over scavenging.
Jake Raby
Jun 21 2014, 03:42 PM
According to the camshaft profile, it may not idle at all and low speed performance will suck.. EFI and camshaft profiles are fine lines.
What cam is it?
john maples
Jun 21 2014, 05:25 PM
I don't know which cam is in the motor. Just thought about buying it as a temp while mine (912E) is being overhauled/ upgraded to 2056 specs.
QUOTE(Jake Raby @ Jun 21 2014, 01:42 PM)
What cam is it?
Mark Henry
Jun 21 2014, 08:44 PM
With stock injection I'd have to say no to that.
Even programmable FI has issues with performance carb cams, although there is work arounds.
Carb performance cams have lousy vacuum for the MAP or MPS, really you need at least 15 inches of idle vacuum.
