QUOTE(Jake Raby @ Jun 21 2014, 02:38 PM)
QUOTE(Mike Bellis @ Jun 21 2014, 01:35 PM)
The bolt patterns for T1 & T4 are close. T4 being slightly larger. You might be able to hog it out to fit. It's been done somewhere before
No, they are exactly the same. Just change the two lower bell housing studs from the 914 engine and install some 10mm shorter.
Then just bolt it up. The flywheel compatibility is where the conversion comes in.
So do you sell all the parts necessary for the conversion Jake?
FYI I'm thinking about using my motor in another (light) race car for hill climbs. With the car I have in mind a VW transmission would be more effective than a 901.
