kid914
Jun 22 2014, 07:35 AM
I believe it s called the generator warning light?
It turns on when I start the car. Can I still use the car? dangerous?
Where do I start to fix it ?
Thanks
JStroud
Jun 22 2014, 08:13 AM
The light should come on when you start it, then go off once the car is running.
If its staying on then your charging system is not working. Which means your alternator is not charging your battery. Not dangerous will just drain your battery and your car won't start.
Could be a bad ground or connection, broken/loose alternator belt, bad voltage regulator, bad alternator.
First check ground and battery connections, alternator belt, loose or broken wires to the alternator. Could try swapping voltage regulator if you have an extra, next would be have the altnenator tested.
Hope this helps
Jeff
kid914
Jun 22 2014, 12:34 PM
It helps.
Now I have a starting point.
Thanks
Mike Bellis
Jun 22 2014, 01:27 PM
You can drive just fine until the battery discharges and the car stops running.
kid914
Jun 23 2014, 05:15 PM
QUOTE(Mike Bellis @ Jun 22 2014, 03:27 PM)
Not sure I want to do that.
