SS replacements in hand. Since I was this far in I might as well do both sides.
I could get the pad on but only with one of the latches installed. I had to finesse the other latch with the pad loose. But in the end it was worth it.
Pretty good guess that the correct order for the interior installation is the top pad, then the B pillars. When you do it backwards it's a wee fight.
All done for now, at least this part. One of the latches was actually missing both bolts so I don't have to worry about the top, more or less.
I think I ended up missing a few screws and some of the screw trim caps. Probably find them the next time the interior comes out.
