Hello guys!
Quote: "I’m willing to bet that 80% of the 914’s on the road have inoperative rear calipers."
Is that true?
Well, I've been in the 80% league lately with some struggles adjusting the rear brake calipers. I found they're almost locked hard on the rotors. I first noticed this from a bad gas mileage. The calipers are from PMB so they must be perfect. I just don't get the adjustment right or something else might be wrong.
What's happening is after I set the venting clearances at our favorite spec, it feels great only for the 1st few runs. After that it just gets tighter. It's as tight as you can't turn the rotors by hand. Emergency brake handle's range of movement gets smaller too.
The result of my 2nd try seems to be better than the 1st but I've already noticed the venting clearance's gotten smaller than yesterday.
The rubber brake hoses are not more than 3 years old and the fluid is just bled but the MC might be more than 20 years old.
I will check on the MC push rod to see if it's out of adjustment.
What do you all think?
Thanks in advance,
kkid
