spunone
Jan 19 2005, 09:59 AM
Making some metal patches for the rust bucket which need to be welded on .Where can I buy the weld thru primer to spray on both sides before welding since one side can't sprayed later.Thanks
Rusty
Jan 19 2005, 10:07 AM
3M makes a nice zinc weld through primer that you can buy at most auto body stores. I've bought it at local auto parts stores sometimes, too.
-Lawrence
vortrex
Jan 19 2005, 10:17 AM
yeah I used this 3M and worked good. I got it at an autobody supply store.
spunone
Jan 19 2005, 10:22 AM
Thanks Auto body supply it is
914GT
Jan 19 2005, 10:25 AM
If you can't find it anywhere else locally,
FinishMaster will have it for sure. There are several in the LA area.
spunone
Jan 19 2005, 10:28 AM
Better yet Thanks
airsix
Jan 19 2005, 08:08 PM
I use the 3M as well. Don't give up if the first shop you go to doesn't cary it. I went to at least 4 autobody/paint supply stores before I found "weld-through primer". The first shops didn't even know what I was talking about. The fourth shop had 4 different types.
Bet you can guess where I'm going next time.
-Ben M.
DJsRepS
Jan 20 2005, 07:03 AM
I read this thread too late had no primer before the repair. I did grind and clean and prime with self etching primer from auto paint supplyer. Never heard of weldthrough primer learn sumptin new every day on this club. I did use Galv metal I know it burns off easy near the welded area but the middle galv is intact.
