CTDan914
Jun 25 2014, 03:16 PM
Is there a required torque for the oil filter on a 2.0 and is a special filter wrench needed to remove and install the oil filter?
Cap'n Krusty
Jun 25 2014, 03:27 PM
As tight as you can turn it with one hand. 1.7 and 1.8 oil filters get tightened almost, but not quite, as tight because of the smaller displacement ....................... Oil the rubber gasket before installing the filter. Most of us use giant channel locks or some kind of filter wrench to remove it.
The Cap'n, pullin' your leg a bit.
TheCabinetmaker
Jun 25 2014, 03:30 PM
If you use a German filter, which is the only ones you should use, (mann, or mahle) the installation instructions are printed on the side. You can use whatever will fit to remove it, and hand tight to install. Oil the rubber seal. No need to prefill the filter. I screw it on till the gasket makes contact with the case then 3/4 turn, which is about as tight as I can get by hand.
theleschyouknow
Jun 25 2014, 03:58 PM
1.3 mkp or 9.5 ft/lbs according to Bowlsby's site
theleschyouknow
Jun 25 2014, 04:00 PM
QUOTE(theleschyouknow @ Jun 25 2014, 04:58 PM)
from 1971 service & training manual
CTDan914
Jun 25 2014, 04:42 PM
Great, thanks for the help.
I was able to change the filter and the oil moments ago.
Dan
