Tore my motor down for a rebuild because of a suspected bearing noise.
Guess i was right(in denial). Oh well, done is done, right?
I thought it was odd that it was only on second main bearing and one rod were damaged. What ever was in there made a couple trips around then F'd off.
But was wondering if this burn pattern on the pistons is a sign of any thing.
only 50k on the motor. I havent check fuel pressure yet and whether the injectors are leaking. Did have a surging idle though, From stall to 900 rpm.
