1973 1.7 $4800
Originally from California, came to Minnesota in the late 80’s
I have owned it since 2000
Very clean body and very little rust, jack points are good and hell hole is good.
Mint dash with a newer radio and 6’ speakers
Seats need work and a small tear in the back pad on the passenger side.
New shocks/struts.
New front brake pads
Leaks a dime spot on the floor, I think it’s the drain plug.
Runs good, idols good then a bit high at times, I think the thermostat is stuck. I opened the vents all the way as I only drive the car 3 times a year around the lake.
Tires are like new but they are 12 years old.
The body has door dings and palm dings on the hoods but nothing really bad
First gear works well as long as you stop before shifting into first gear. I put the shift bushings in 13 years ago and I think it needs them again as it seems it was tighter a few years back.
The car needs a complete Carpet Kit
PM me here for more information.
