I have a 1996 993 rear hub coming to see if they will mate up to the 914 rear arm. They both use the same rear wheel bearing and appear to be close to the same size. It would be nice to find a hub centric replacement. I will be testing to see if the 100mm 911 SC stub axle will bolt up. There might even be later stub axles that can be used. It will be next weekend before I will get started.
Any thoughts out there?
