A friend of my dad gave me these. They are just under 30mm raised. They also are shortened one inch. The tie rod arm has been modified too. The brake calipers mounts are 3 1/2 inch on center too.
Should I clean them up and use them?
Worried about the 1 inch shortened mod and the bent tie-rod arm. I assume the tie-rod is bent to help with bump steer?
I already have early 911 towers. So my brakes should mount right up.
If I space out the front wheels, can I still use 15 inch wheels? How much spacing?
Decambered ball joints help with fitment too?
As usually, all help is good help.
