QUOTE(Jesper2803 @ Jul 7 2014, 01:33 PM)
QUOTE(Jeffs9146 @ Jul 7 2014, 11:54 AM)
QUOTE(Jesper2803 @ Jul 7 2014, 12:29 PM)
Ohhh f..k!!! Dit it mess up the intire gearbox??? What bearing is that? Pinion?
No it was just whining and it didn't fall appart until I removed the shaft from the intermediat plate!
Ok.. Did the whining stop once you changed the bearing?? And is there any special tools needed to do the fix??
Jesper denmark.
Yes my trans works great now! I replaced some syncros, and dog teeth while I was in there! All the parts were used but in good shape so it only cost me about $450!
You should get the DrEvil Transmission Rebuild Video and decide if you can do it! It does require some special tools and knowledge and the "While your in there" should be considered!
I did mine at the Dr's Clinic in Napa and have done a total of 3 so far with every one is still working very well!
