QUOTE(dudzy's914 @ Jul 7 2014, 09:00 PM)
If I sandblast the wheels, do I use self etching primer, or run sandpaper over the wheel and use regular primer/sealer?? What do I do after blasting?
Sandblasted surface really isn't good enough to paint directly. Etching primer will save a lot of elbow grease. Sanding is called for if you'll use 'regular' primer.
I've used a phosphate (acid) wash on some old truck rims to prep the blasted surface before 'regular' primer, but they've never been in the weather so I can't say yet how well it works.
cm
