I have read several threads concerning the rear trunk lid not lining up seems like in most cases the hinge side of the trunk sits high and the latch side seems mostly flush. I have the opposite going on the hinge side is maybe 3/16" high but the latch side is closer to 1/2" high
so does this look like a failing hinge mounting plate or a sheared bolt or something else
I have checked the rubber stops they are screwed in all the way the latch plate seems to be as low as it can go
ah ha. just noticed previous repair of hinge mount on d side so I assume it didn't go back in the right spot?
now a matter of cutting the repair & rewelding I guess?
car is pretty original so I'd rather go stockish rather than jwest/camp914 route
and can it be done without complete disassembly? I just got this car so I'd rather not drop the engine & trans etc. I adjusted the p side rubber stop out a little and that helped the d side latch end of the trunk but hurt the p side now they both sit about 1/4" high at the latch end of things
no pics cause they kept turning out upside down - how do you fix that?
