QUOTE(David_S @ May 30 2003, 07:53 PM)
Question is ...should I replace the whole tube with a piece of steel tubing or can I just cut out the section that is plugged and splice it back ?? thanks in advance ....David
Yes.
If you splice it you may still have trouble sliding the cable through. You could try that first and if it doesn't come out right try the other way. If you replace the tube, braze it don't weld it. That's how the factory did it, since welding might overpenetrate and make it impossible to slide the cable through.
