Does anyone have the specs for the distributor advance?
Both the mechanical and vacuum numbers are needed.
I am starting my Megasquirt project on my stock 2.0 and I am thinking the best place to start would be to replicate the stock settings.
I can look up the total timing setting, but I am more interested in seeing the mechanical advance curve so I can make the curve as close as possible. Then I will be adding in the vacuum advance from the MAP sensor.
Thanks!
