cpavlenko
Jul 10 2014, 09:44 AM
Does this steel piece go on the back side of board or front.
GaroldShaffer
Jul 10 2014, 10:31 AM
back
cpavlenko
Jul 10 2014, 01:27 PM
thanks, that's what I thought.
GeorgeRud
Jul 10 2014, 01:31 PM
Back side with the rubber bushing facing the pedal arm.
cpavlenko
Jul 10 2014, 01:45 PM
What rubber bushing?
Eric_Shea
Jul 10 2014, 04:07 PM
The one you're missing.
It slides in the tray. Take a picture of the other side.
cpavlenko
Jul 11 2014, 01:11 PM
So what does this rubber bushing look like, cause I don't have one?
StratPlayer
Jul 11 2014, 01:19 PM
hope those drain hose's worked out for you
cpavlenko
Jul 11 2014, 01:28 PM
Yes they did, good fit, thank u so much.
GeorgeRud
Jul 11 2014, 04:21 PM
It's just a solid piece of rubber that slides into that bracket to provide a soft stop for the pedal arm. I would imagine that one of the parts places should have one available. If no luck, try Brad Mayeur at 914Ltd in E. Peoria, Il as he has a stash of parts cars.
RenoRoger
Jul 11 2014, 05:28 PM
You should be able to make that rubber bushing yourself. Slide and glue a piece of fuel hose to it.
My pedal board made out of particle board by Porsche, what a crummy idea, was falling apart. After I saw a car with a metal board at the recent WCR, I took mine as a pattern to a sheet metal shop and I am having one made as we speak.
RenoRoger
TheCabinetmaker
Jul 11 2014, 06:10 PM
I've never seen a pedal board made from particle board. All that I've encountered were 16mm plywood. Maybe an early model?
RenoRoger
Jul 11 2014, 06:24 PM
QUOTE(The Cabinetmaker @ Jul 11 2014, 05:10 PM)
Mine is a '73, very, very original with a black painted pedal board, made out of compressed sawdust=particle board. if it had been plywood, it would probably be still
O.K.
TheCabinetmaker
Jul 11 2014, 06:47 PM
Ok. I learned something new.
GeorgeRud
Jul 11 2014, 07:05 PM
My 73 also had a particle board panel that fell apart as well. Must have been trying to save money back in those days at the factory.
cpavlenko
Jul 11 2014, 07:16 PM
My pedal board is still original. I'll try 914LTD and c if they have the rubber bushing, if they don't, I'll try the fuel line trick...
