QUOTE(jrrhdmust @ Jul 10 2014, 01:19 PM)
So there is a sensor on the pedal assembly, and my assumption this is the brake light activation sensor.
So my question is how are the wires routed? I can't remember what it looked like when I pulled it apart. Thanks for the assistance.
On the pedal box inside the car you will see a switch mounted in front of the brake pedal. It is the brake light switch. It has no connection with the hydraulics, it is activated by releasing pressure on the brake light switch.
Click to view attachment#23 is the brake light switch. It contacts the big round washer #48.
There are two wires connecting to it. They are not specific to a terminal, they can be hooked up either way.
Hope that helps.
