Swapping out tachs for my /6 conversion - the 911 tach has left and right turn signals vs. just one light for the /4 tach. I've found the instructions to do this but I'm a little confused. The blue/white wire from the turn signal flasher feeds the single light on the /4 tach. The instructions say to split this to both lights on the /6 tach - then run 2 wires from the emergency flasher that feed the exterior front/rear lights.
If those 2 wires are feeding the exterior lights and the blue/white wire feeds the interior light - isn't that 2 positives feeding each other if I hook them all to the tach lights?
