QUOTE(buck toenges @ Jul 11 2014, 11:50 AM)
Is there a fuel pressure regulator bracket for a 1970 1.7 engine? I assume if there is one would it be located on the engine tin or engine block? Or does the fuel regulator just lay on the engine tin?
Thanks,
Buck
It is an L shaped piece of sheet metal with a hole in it for the regulator to attach to. If it is broken off and gone you can attach one to the engine tine with sheet metal screws or rivets if you don't want to weld it. I had to fabricate and weld mine in. Long gone.
