QUOTE(914itis @ Jul 11 2014, 09:12 PM)
if it is DJet, It may be your trigger points. Easy to test
I agree.
trigger points fire in pairs
could be one side of the trigger points not working
most likely the wire that plugs into the bottom of the distributor
idle the car and wiggle the wire connector to see if it comes and goes
that wire group often fails... a connector repair or wire crack is likely the cause
