Trekkor
Jan 20 2005, 08:34 PM
1. 162
2. 155
3. 148
4. 145
5. 140
6. 162
Not too alarming, is it?
KT
Dr Evil
Jan 20 2005, 08:35 PM
Is it broken in yet? Have the rings fully seated? Does that matter?
Joe Bob
Jan 20 2005, 08:41 PM
It ain't great....did you do it with all the plugs out, hot engine and WOT?
Have you done a leak down?
Have you tried a little oil in the low holes and recheck?
Trekkor
Jan 20 2005, 08:45 PM
Did it bone ( freezing ) cold, WOT and only plug out for each hole being tested.
KT
jim912928
Jan 20 2005, 08:50 PM
what mike said...engine should be warm and all the plugs out. If you find any cylinders low squirt some oil down there and recheck. If the pressure comes up to be more inline with the others then it points to rings. If it doesn't matter it could be valves. Leak down will be your next test.
Trekkor
Jan 20 2005, 08:56 PM
Why do the other plugs need to be out?
KT
scotty914
Jan 20 2005, 09:00 PM
you dont want the starter fighting the compression stroke on the other cylinders, or drawing a vacumn on the intake
McMark
Jan 20 2005, 09:09 PM
The engine spins easier and faster with all the plugs out.
Joe Bob
Jan 20 2005, 09:13 PM
AND it simulates real time running....at high rpms....you're trying do a check at highest operating level....
Joe Bob
Jan 20 2005, 09:15 PM
QUOTE (trekkor @ Jan 20 2005, 06:56 PM) |
KT |
JUST DO IT AND STOP ARGUING.....
Works with my kids.....
boxstr
Jan 20 2005, 09:18 PM
KT I have a freshly rebuilt 2.0 four I'll trade you for the weak six.
CCLINSORRYCAN"THELPMYSELF
Trekkor
Jan 20 2005, 09:19 PM
So, a warmed up motor and plugs out will give me improved numbers?
KT
scotty914
Jan 20 2005, 09:20 PM
one word..... yup
jim912928
Jan 20 2005, 09:21 PM
might not be improved but they will be more accurate. Oil will be all around the cylinder walls and tolerances will be better with things being alittle warmer.
Trekkor
Jan 20 2005, 09:28 PM
Where should the numbers be?
KT
iiibdsiil
Jan 20 2005, 09:37 PM
Consistency is the key thing. I think the allowed tolerance is 12 psi, but I could be wrong. Looks like you should be about 160.
Joe Bob
Jan 20 2005, 09:42 PM
170 and above is great.....
Trekkor
Jan 20 2005, 09:50 PM
A local mechanic said no more than a 25% differance between best and worst.
I'm at 14%
KT
jim912928
Jan 20 2005, 09:58 PM
post your new numbers...they should get closer. But even if they do not improve I don't think they are drastic enough or low enough to warrant tearing anything apart. Just drive and have fun!
Gint
Jan 20 2005, 10:01 PM
I've run worse. 14% isn't great, but it'll run OK. Don't worry about it.
Trekkor
The low cylinder is the one I'm having trouble with... getting it to fire at idle.
KT
rick 918-S
Jan 20 2005, 10:03 PM
QUOTE (trekkor @ Jan 20 2005, 07:50 PM) |
I'm at 14%
KT |
14% true, but the method you used to achive the readings are not correct. Check them again to be sure.
Gint
BTW:
with Rick
Try new plugs yet? Take those carbs apart and clean out the sealant?
I don't think the 14% difference in compression is the root cause of that cylinder not firing at idle.
iiibdsiil
Jan 20 2005, 10:06 PM
It's hard to say what the PSI should be at because I don't know the compression for your motor, or the conversion from a ratio to psi...
25% sounds pretty high though to me... When I checked my motor I was within 9 psi on all 6 cylinders. I can't remember for the life of me what PSI it was, but I am sure it is higher than yours.
25% might be acceptable, I guess. I mean, it all depends on what your tolerances are. Same thing with alignments, the factory has a broad spec, and if you don't care, you take it to the alignment shop and say align it, if you do care, you watch over them, and tell them that you want it closer.
I'm not sure on the story of your motor, haven't been paying attention at all, but if it was a freebie or you didn't spend a whole lot, then run it and enjoy it. If you want it to be closer to perfect, then worry about it.
But, you need to do the compression check right first, all plugs out, WOT. If readings are still varying like that, put a couple drops of oil in the cylinder, and see if that helps. If not, get an adapter and do a leak down test. If you hear air coming out of the exaust, you have an exaust valve that is screwed up, coming out the intake, I bet you can figure that one out. And if you hear it out the oil cap, or however you can hear the crank case on a 911, then it is rings whatever else would allow air into the crank case.
Martin Baker
Per Factory Manual...Reference 10.2-1/1
128-156 PSI, Oil temperature at least 60 degrees C/140 degress F, pressure uniformly distributed between cylinders. No mention of percentage of variation between cylinders. I have read up to 20% on other engines as well.
Martin Baker
Jan 20 2005, 10:09 PM
With a 160 reading cold I would guess this engine to have higher than original compression...
Trekkor
Jan 20 2005, 10:10 PM
I have not cleaned up yet...
Martin Baker
Jan 20 2005, 10:16 PM
Number I have written previous are for 2.0 liter 914-6, 8.6 to 1 compression. Your engine 901/06, 1967-68 911 (all) 9.0 to 1 compression. May be normal reading for 9.0 to 1 compression...my mistake. I own no 911 manuals at the moment for compression data.
Trekkor
Jan 20 2005, 10:17 PM
Plugs are new Bosch Platinum's.
KT
Gint
Jan 20 2005, 10:20 PM
My .02 - Time to take the carbs down again. Get that sealer out. Dip 'em. And get some NGK's. Check the plug wire on that cylinder. This all sounds so familiar. Except for the sealant on the carbs part. Lawrence just did most of that same song and dance.
IronHillRestorations
Jan 20 2005, 10:32 PM
TREKKOR!!! Are you trying to find trouble? I wouldn't worry about it until you get at least 500 or more miles on the engine. A engine that's sat won't have good compression until it gets "re-broke in". The main thing is how the engine runs.
Are the plugs the fine wire platinums or the $$$ platinums? If they are the fine wire, throw them away and get the Bosch Supers or the $$$ platinums. Fine wire platinums are for INJECTED engines. Your carburatted engine will run too rich and foul the fine wires real quick. There is just a little dot of electrode there on the fine wire plugs.
To check the idle circuit on the suspect cylinder you can back out the idle jet, just a little bit, like a half or 3/4 turn or so. Not the mixture screw, but the actual idle jet carrier. If the engine stumbles a little then that jet is working. If nothing happens then that idle jet is probably clogged.
Trekkor
Jan 20 2005, 10:48 PM
$$$- no doubt about it.
They were about $25...each.
thanks for the info, all.
KT
Jan 20 2005, 10:59 PM
QUOTE (trekkor @ Jan 20 2005, 08:48 PM) |
$$$- no doubt about it. They were about $25...each.
KT |
Well you won't foul them easily! Those are the real deal. I won't tell your wife how much you shelled out for spark plugs
Try the idle jet trick. It can save you all sorts of hassle.
newdeal2
Jan 20 2005, 11:06 PM
QUOTE (trekkor @ Jan 20 2005, 07:19 PM) |
KT |
Try it HOT...after a good workout. I did and the numbers bumped up [allthough still a range]. I am waiting until the rings have about 500 miles then a retest. From all the info I have been given it's crucial to wait for the rings to seat. I have also heard a cam will throw numbers off due to the longer duration.
Is this freshly built? If so relax and see what happens...if it runs strong and doesn't smoke what's the problem
Trekkor
Jan 20 2005, 11:18 PM
Not a fresh motor? Mystery motor all the way.
Based on a 2.0 case. Could be *built*.
Pulls strong. Scary fast.
Fires up, warms up, doesn't die, runs cool, I have a few little issues.
It'll work out.
two months 'til a/x season.
( JP, come down here )
KT
Trekkor
Jan 22 2005, 03:54 PM
Good news to report:
Went out for a hot up run. Did a recheck on #5
160#'s!Much better than 140.
I guess I'll break the carbs down and hunt out the clogger.
KT
ein 6er
Jan 22 2005, 07:33 PM
trekkor,
congrats on getting your project running, the sound of a 6 is sweeeeet, isn't it!! sorry you are having problems.
i also have a '67 2.0 mystery motor, 901/05. i'm guessing i only have about 135 hp.
i had the same thing, it would only fire on 5 at idle. i tried new plugs/wires/cap/rotor/points, my compression #s were all even, didn't do a leak down. i thought the idle circuit was plugged, i tore them down about 4 times and soaked them. i replace all the intake gaskets. even after that, the one cylinder wouldn't fire at idle. adjusting the air screws had no affect on idle.
never determined exactly what was causing it, but i had my dizzy rebuilt, (i had excess play in the shaft) and went to the crane optical trigger. i also had the throttle shafts rebushed and readjusted my valves. it's been running perfect since.
check your dizzy shaft for play, and lube it while you are in there. also check your throttle shafts for play.
hope you get it figured out!!
doug
Trekkor
Jan 23 2005, 01:36 AM
Oh, yeah.
I tried a set of the NGK's Gint recommended.
Seems like an improvement. No soot on the plugs after a good run.
The #5 cylinder which is not running at idle does get hot like the rest of them. It is firing off idle.
KT
