QUOTE(ClayPerrine @ Jul 12 2014, 06:22 PM)
QUOTE(boxsterfan @ Jul 12 2014, 04:25 PM)
Troubleshooting fuel pump. PO moved fuel pump up front on a 74 2.0L.
At the pump I see the brown ground and a red wire (+) that is hooked to a black wire (not a yellow/black wire).
The PO wired the pump to some power up front, but where can I find that? Where would the ground from the pump and power come into the chassis/cabin?
All you can do is follow the wire that the DAPO used. But I would guess it probably goes inside the car to the fuse box.
Make sure to find the fuel pump wire in the engine compartment and run it up front to the pump. It will work correctly if you do that.
Well, I replaced the relay board, cleaned up all the connections on the fuse block at the driver's knee with some light sandpaper, and cleaned the ground connection to the chassis by the fuse box. I checked voltage at the fuel pump and was getting 11.88v. Before, I had been getting only ~10.5v so maybe my problem will go away. I also stuck a small ice pick like device into the connectors at the fuel pump and "tweeked" them a bit so that they slid on tigher to the male connectors on the pump.
Unfortunately, I have 12 gallons of gas in the tank right now. I'm going to get that re-wired to run off the power from the back but I'm going to tackle that when I can drain the tank easier (like when I am near empty). Hopefully, she'll run until I can get her emptied out.
