Still tracking down an intermittent miss under hard acceleration.
So I was looking at fuel pressure this afternoon.
at idle I have 34psi.
If I slowly accelerate the engine the pressure drops to 30psi.
With a quick snap of the throttle the pressure will jump up to 40-45psi but then quickly drops back to 30psi.
Does this seem to be where I should be as far as correct pressure numbers Or do I need to invest in an adjustable pressure regulator?
Also I am running pretronix and questioning the coil. I am using a standard Bosch blue coil.
Do I need to look at something with higher performance for in a 2056?
