jwalters
Jan 21 2005, 07:09 AM
Whoo hoo! All is back from the blasters!!
I am so happy I ponied up the coin to have this done! It has saved me over 3 weeks of personal stripping--not to mention all the defects the strip job has found for me that I might have not seen!!!!
jwalters
Another----
jwalters
Jan 21 2005, 07:10 AM
Another..........
jwalters
Another................
jwalters
Jan 21 2005, 07:11 AM
Another............
jwalters
Another..........
jwalters
Jan 21 2005, 07:12 AM
Last one-----------
vortrex
Jan 21 2005, 07:14 AM
so what did it cost and what medium did they use?
CptTripps
Jan 21 2005, 07:20 AM
That looks like what I wanted to do.
How much, and how long did it take?
vortrex
Jan 21 2005, 07:24 AM
$575 for blast and primer? if so that is the deal of the century.
vortrex
Jan 21 2005, 07:34 AM
that is a crazy deal. I think the place where brad did dipping was like $3k for dip and primer.
Stutgart46
Jan 21 2005, 09:18 AM
The car looks great. I don't see a whole lot of issues with this car. It looks like a great starting point.
Root_Werks
Jan 21 2005, 09:28 AM
Just over $700 for that! Sweet! Looks great!
scotty b
Jan 21 2005, 09:38 AM
Lookin good J! So you ready for a 924 now??
I charged a guy 650 to do a L.E. a few years ago and felt like I got ripped off! That's some nasty work.
JmuRiz
Jan 21 2005, 09:40 AM
Now that that's done, time to put in that Inner Long Stiff kit :-) If it's going to be a street car w/o a cage that is. I'm jealous, car looks great and you didn't have to break the bank
jr91472
Jan 21 2005, 10:47 AM
looks like your avatar got stripped pretty clean too.......
sorry, couldn't resist
gopack
Jan 21 2005, 10:58 AM
I see what looks like the brake proportioning valve and the wiring harness still in the car! what did you leave on/in the chaisis? I always assumed I would have to take out the wireing harness and everything, and I have been putting it all off for that reason! (I have the "as long as..." disease bad! As long as I'm doing this, I might as well do that).
how did yoo protect what you left in?
any info would be apreciated.
jwalters
Jan 21 2005, 11:10 AM
QUOTE (gopack @ Jan 21 2005, 11:58 AM) |
I see what looks like the brake proportioning valve and the wiring harness still in the car! what did you leave on/in the chaisis? I always assumed I would have to take out the wireing harness and everything, and I have been putting it all off for that reason! (I have the "as long as..." disease bad! As long as I'm doing this, I might as well do that). how did yoo protect what you left in?
any info would be apreciated. |
Thanks everybody!!!
Go pack--I could have done this--but I want to ride now!!! and the old harness is in such good shape I could not bring myself to possibly "F" something up in the process--it ain't easy for how far i got it to this point.
I removed the fuse block and pulled all the wire back to just the point where it all goes inside the tunnel. I then balled it all up and double trash bagged it and blue taped the neck of the bag to about one foot away from it, so everything from outside the tunnel is wrapped--
Same thing in the hell hole--only I blue taped the rubber harness covers where they protrude from the chassis, and then balled everything up and bagged it all.
I was not concerned with color coded wire--all I was concerned about is the codes where they terminate--the entire loom is going to be re-taped so any overspray is nothing to worry about.
Saved me allot of time and extreme cussing from pulling and replacing all that wire thru the tunnel-------and again to emphasize---it is all just the way it was put in the car--to a degree--I KNOW I did not screw anything up!!!
Jan 21 2005, 11:12 AM
they look so pretty when they're naked!
you should have removed the wire-harness as well. only takes half an hour ...
looks great!
Andy
bondo
Jan 21 2005, 11:21 AM
Awesome! I'd do that if there was a place around here that cheap.. I should look around.
Did they leave any baking soda in the passenger side longitudinal to neutralize battery acid?
