Both my sill covers have small crack from the underside and about an inch upwards about 10-12 inches in from the rear end, since both mine are cracked in the exakt same place I'm wondering if this is a common issue?
I'm going to drill a hole at the end of the crack and then weld them back up. Will probably weld up the jack holes to achieve a smooth look on the sill covers while I'm at it.
