11mm socket on a wrench, then get under the car, there is an adjuster nut on each side where the torsion bar tube meets the crossmember.
Tighten to raise the car, loosen to lower the car.
Note that any major change in ride height should be followed by at least a 4 wheel alignment, better yet a corner balance and then an alignment.
