mikea100
Jul 18 2014, 08:49 PM
FS. FI harness $30 + shipping.
mikea100
Jul 19 2014, 06:49 PM
Can anybody help Id these? Thank you!
worn
Jul 19 2014, 07:52 PM
QUOTE(mikea100 @ Jul 18 2014, 06:49 PM)
FS. 2 FI harnesses $60 + shipping for both.
Look like injector harnesses but I don't recognize them beyond that. I don't know much about what a 1.8 oughta look like, but is it possible these come from a related 4 pot such as the 924? Just my ignorance here.
Black22
Jul 19 2014, 08:07 PM
Look like L-jet harnesses.
JeffBowlsby
Jul 20 2014, 08:32 AM
If they are from a 914, they look like the L-Jet FI harnesses from the 1974-75 cars.
Check the air flow meter connector - 6 pins is 1974, 7 pins is 1975.
mikea100
Jul 20 2014, 06:06 PM
Thank you, Jeff! I can confirm that these are the L-Jet harnesses and one of them is for MY '74 (6 pin) and second is for '75 (7 pin). I'm attaching photo of the air flow meter connectors.
mikea100
Jul 20 2014, 06:17 PM
PS. I have the injectors for L-Jet for $50. Will combine both lots for $100.
MartyYeoman
Jul 21 2014, 01:59 PM
There are 914 L-Jet harnesses and there are Bus L-Jet harnesses.
I'd be interested in the 7 pin if it's specific to the 914.
I can send along a specification to confirm if needed.
Marty
mikea100
Jul 21 2014, 06:24 PM
QUOTE(Marty Yeoman @ Jul 21 2014, 03:59 PM)
Marty
Marty,
Please send the specs, I'll be happy to confirm.
Thanks,
Mike
MartyYeoman
Jul 21 2014, 08:50 PM
The harness on the left is for a 914. The one on the right is for a 2.0 Bus motor.
Note that on the 914 version, the AFM connector is on the opposite end from the control module connector. On the bus version, the AFM connector exits midway along the harness between the control module connector and the injector connectors. The 914 version is also a lot longer than the bus version.
In the picture on your first post, which harness is the 7 pin harness?
Marty
mikea100
Jul 22 2014, 08:50 PM
It's a 914 harness, see picture.
Grump
Jul 23 2014, 06:51 AM
QUOTE(mikea100 @ Jul 22 2014, 10:50 PM)
Is the 7 pin still available? Thanks
mikea100
Jul 23 2014, 07:29 AM
Both of them are available. I'd prefer to sell them as a package for $60 + shipping, but
can split them $40 each + shipping.
Grump
Jul 23 2014, 02:20 PM
I'll take the 7 pin. No need for a Bus harness. Does the harness look to be in good condition? No broken wires or burnt spots? Outer insulation in good shape? If so, send me a PM with payment info. Regards Bill
mikea100
Aug 2 2014, 02:43 PM
One harness left. $30 + shipping, which is $12 flat rate box.
mikea100
Sep 9 2014, 06:18 PM
mikea100
Sep 26 2014, 01:03 PM
brooks944
Sep 26 2014, 05:16 PM
Is the 75 harness still available?
mikea100
Oct 13 2014, 12:22 PM
mikea100
Oct 30 2014, 08:48 AM
rick 918-S
Nov 2 2014, 12:05 PM
pm sent for the 74
mikea100
Nov 2 2014, 03:10 PM
All terminals seem to be intact. Pictures of terminals:
mikea100
Nov 2 2014, 03:11 PM
more
mikea100
Nov 2 2014, 03:14 PM
This is some kind of square connector (like spade connector) with piece of wire stuck on the other end. The connector itself seems ok.
mikea100
Nov 13 2014, 03:45 PM
good harness, not a core.
mikea100
Dec 8 2014, 01:32 PM
