During the re-assembly of the fresh air box and relate cables I tried to use the same location for the cable clamps so that the adjustment would be correct. Now that the box is installed the adjustment seems to be off significantly when the controls are moved as far left as possible all three levers are more centered than left.
What is the best method to use for making the adjustment of the controls? Are the adjustments made at the control end of the dash levers or in the front trunk holding clamps?
Kelvin
