The 914 with a roll cage (properly designed) and a 914 without a cage are entirely different all together. (This is where you all re-read that first line out loud
) Joking aside whatever tuning you do to its suspension before the cage will have to be redone after the cage.
I'll give you a little anecdote from my experience with my 914:
Bought my car with a cage in it. Nice looking cage, tig welded, clean, straight, etc. I did not pay much attention to the design outside that it would meet historic rules. The first time I had it out on track it felt great. I had to fiddle with the rear rebound a bit to get the car to stay planted under hard braking but otherwise the chassis was fairly innocuous.
After a few months with the car I notice there was no structure tying the cage to the rear of the car. None at all!! I also discovered on the passenger side of the floor pan there was some stress cracks where the floor meet the firewall! Yep the whole rear of the car was flexing bad! The chassis was doing the work for the suspension! I added tabs from the cage to the seat belt anchors as a temporary solution a few days before my next track outing. And I removed and inserted new steel at the firewall floor joint. Suddenly I was experiencing over steer in three different corners around Sebring!!
If your testing and tuning is to make sure the motor is healthy, have at it. If its to see if you like the sport, great. IF on the other hand its to see if you like the platform or to dial in the car, do yourself and the 914 a favor and get the cage in first.
My 2 cents worth.
Miguel
