john_g
Jul 25 2014, 06:05 PM
I'm looking for a replacement stock distributor for my '74 2.0 fuel injected, but want to make sure I have the correct part number.
I think it's Bosch #0-231-174-011, VW# 039-905-205A. Are these the correct numbers? If not, what's the part # I should look for? And ... will any other distributor work? (Note: I'm not interested in going with a 009 and carb set-up).
Java2570
Jul 26 2014, 06:09 AM
That is the correct # dizzy for a '74 2.0L....same one I have in my '74. You could try using a dizzy from a '73 or '75/76 but it won't be optimum for your setup. I've not tried it so I can't speak from experience....probably would need to recurve the advance if you used one from a different year.
http://members.rennlist.com/pbanders/DJetParts.htmThis link is a good source for part #'s and info on D Jet.
john_g
Jul 26 2014, 01:58 PM
QUOTE(Java2570 @ Jul 26 2014, 05:09 AM)
Thanks for the info and the link.
