I have a 1972 1.7. Pulled the engine to fix a few things.
Replaced...
Front crank seal.
Rear main seal.
Clutch
push rod tube seals.
valve cover gaskets.
oil cooler seals.
oil pressure sender.
I still have a oil leak. Oil drips off the bottom off the fan housing. So I pulled the fan back off to check the front seal.( engine still in the car)
The back of the fan is not oily. Where else can it come from? Can I run the engine for a short time without the fan on to look for the leak, without hurting anything?
Thanks for the help......
